finally got custom predator tune
Old Aug 14, 2003 | 03:31 PM
one03sierra's Avatar
Formerly one92rs
Default finally got custom predator tune
finally got it in. going to install it tonight and i will let you know.
set fuel trims.
raised idle approx 100rpm's
raised cot temps so no extra fuel at wot
got rid of all traces of tq management
and dialed in my fuel and timing.
will keep you posted.
Old Aug 14, 2003 | 05:02 PM
goshawk23's Avatar
Truck addict
Default Re: finally got custom predator tune
i hope it works out for ya. make sure you post how it feels compared to the stock predator.
Old Aug 14, 2003 | 06:41 PM
Formerly one92rs
dude this is awsome.i had absolutely no probs.it shift fast and hard.it accelerates much faster.it just plain runs so much better.i would definitly get a custom tune if needed. mine rocks. thanks to james at runnin.
Old Aug 15, 2003 | 08:24 AM
goshawk23's Avatar
Truck addict
hmmm, wonder if a custom tune could help me out. I don't think i really need one but, every little bit helps.
Old Aug 15, 2003 | 08:47 AM
TG02Z71's Avatar
Hey 02denali, glad to hear James got your tune done. Looks like he came through looking at the most recent reply. So you said all the torque management is history. I have loads of it left, unless my truck is exceptionally weak or some thing. My old 2wd, 2000 5.3l w3.42 gears roasted the tires without a problem. What gives man, my new truck has problems out of the hole creating wheel spin. Not like I just want to burn em all day but once in a while is fun. Maybe I should quit whining and be happy I have traction.
Maybe a e-mail to James is in order for me as well.
happy for ya man!!
Old Aug 15, 2003 | 10:46 AM
Hey 02, what are the settings? Go into "view parameters" and see if it has the settings for the fuel trim, spark, shifts, etc.
Thanks, Jim
Old Aug 15, 2003 | 07:06 PM
Formerly one92rs
feul trim setting are while cruising at 70=ltbank 1 -1.56 and bank 2 -2.34. wot 0.00. kinda in a hurry. i will sit down later and list all settings.got spark turned up +4.0 with no kr. am going to turn it up again. later.
Old Aug 15, 2003 | 07:34 PM
What the difference between short term and long term fuel trims? Which do I base it on? So, when I'm crusing at 70 and mine are higher than 1.56% (which do I look at, long or short?) I need to go - on my power enhancement (lean it out?).
Thanks, Jim
Old Aug 21, 2003 | 04:25 PM
TG02Z71's Avatar
Wow. I've been away a while!! Did you guys ever get the numbers off the custom tune done by James? I was looking at the diagnostic mode and also would like to know what is the difference between long and short term on both settings. Let me know if you can. Thanks.
Old Aug 21, 2003 | 08:10 PM
Formerly one92rs
watch your long term ft.they need to be -. the max they should be at 70 should be 1.56.if it is getting higher then you need to get ahold of james.
