Filthy tb/manifold !!
Old Apr 20, 2011 | 05:56 PM
jeffz0rz's Avatar
Default Filthy tb/manifold !!
pulled my intake today and found this. ive had the truck about 2 and a half years, NEVER ran with out a filter or even touched my intake for that matter. im assuming the previous owner had some sort of intake on the truck. all the bolts that hold the lower air box are MIA, and you can just tell when something has been tinkered with.
i clean the tb, it was completely caked on the inside, as well as the intake manifold. wtf do i do now ? the truck runs good, throws no codes, even compression ect. im worried about what the valves and pistons look like.
Old Apr 20, 2011 | 05:59 PM
RibeiroBJJ's Avatar
Praise The Lowered
Nothing to worry about..very common..That would be the good ol EGR (puts exhaust gasses into your intake) and pcv system (puts blowby into your intake)
Thats is why I deleted the egr and have catch can......
Old Apr 20, 2011 | 06:08 PM
jeffz0rz's Avatar
so thats not dirt? seems like i need to search for some egr delete info. i was blown away when i saw this. this has to mean my valves looks the same way, correct ?
Old Apr 20, 2011 | 06:19 PM
chevyrace47's Avatar
yeah, they probly look pretty nasty. but it shouldn't be anything to worry about. unless its really high mileage, they'll keep running fine. you can thank the EPA for all that nonsense.
Old Apr 20, 2011 | 07:12 PM
offroadrider12's Avatar
umm isn't that a DBW throttle body with no EGR?
sometimes intake crud can also be related to the PCV valve hence why people install catch cans.
I like to put a little grease on all of my rubber boots on the intake connections to make it a tighter seal.
Old Apr 20, 2011 | 09:12 PM
jeffz0rz's Avatar
yes, i have a dbw tb. AND i think i f'ed something up. im getting 0107 and a 0443 code.
Old Apr 20, 2011 | 09:32 PM
jeffz0rz's Avatar
that stuff doesn't work. ive been drinking it all day and my truck is still throwing codes.
Old Apr 20, 2011 | 11:48 PM
cdub81's Avatar
p0107-Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
p0443-Evaporative Emission Control System Purge Control Valve Circuit
Double check everything you unhooked/cleaned and make sure its correct.
We're you having these problems before? If not then something is not connected back properly or was damaged during cleaning.
GL
Old Apr 20, 2011 | 11:59 PM
jeffz0rz's Avatar
didnt have these before. im thinking i didnt plug something back in. guess ill be checking everything in the morning.
Old Apr 21, 2011 | 11:28 AM
jeffz0rz's Avatar
checked everything this morning, and its all plugged back in and hooked up properly. not sure what else to check. i did the tb bypass, its the only thing i changed. that cant be throwing a code though can it ? dis connected the battery, then im going to drive it a little to see if anything clears up. not sure what else to check. any idea specifically where to look since im getting those 2 codes ?
