a few questions
Old Jul 4, 2009 | 05:23 PM
Lowered 93Z's Avatar
Default a few questions
ok guys i hope you can help so here we go
first i am making my own catch can for my truck and i was wondering what was the proper way to hook up the hoses and is it worth pulling the intake off and cleaning it out after i install the catch can
second i use my truck as a truck still (pulling snowmobiles and other toys) i want to put a stall in it and a shift kit how big of a stall are you guys runing and still pulling stuff with ? Thanks alot
Old Jul 5, 2009 | 12:46 PM
SilverDog's Avatar
On the catch can go from the pcv valve (on the back of the driver side valve cover) to the can, from the can to the port on the top of the intake manifold. When making the can just make sure you have sometype of divider inside of the can to separate the intake and exhaust(plus post pics).
On the stall I'll have to pass(no experience). I would do the vette servo and bigger trans cooler if you tow.
Old Jul 6, 2009 | 04:05 PM
ok thanks as far as the vette servo what does that do?
Old Jul 6, 2009 | 04:25 PM
SilverDog's Avatar
Kind of hard to explain(aka= I have know idea so know I'll BS an explanation, jk). I think it increases the clamping force on the 1-2 shift and 2-3 shift. Design to prevent slippage. For a simple $15 item and around an hour of install time it's worth it. It fells like it firms the initial shifts up and makes them almost seem quicker. If you do a search I guaranty you will find nothing put positive responses to installing it. Someone else will chime in.
Old Jul 6, 2009 | 07:03 PM
peterls1's Avatar
Default Stall
IMO i have heard people usin a stock trailblazer stall convertor, or a small 2500 nothin bigger than that. There was a 2500 for sale the other day on here for like $125 in the Texas section or classifieds, sounded great to me. I have pulled with a stall once but mine is big and didnt feel too good imo. Good luck.
Old Jul 6, 2009 | 07:51 PM
charcoal03silvy's Avatar
Whats the TB stall at RPM wise?
Old Jul 7, 2009 | 01:58 PM
right now the trans is stock. the truck has the newer z06 cam with shorty headers and true duals. i was thinking about a 2400 to 2800 stall so 2500 would work good what is the stall on a trail blazer converter? and do you guys think a trans cooler is a must or will the stock one work?
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
