FAST manifold progress
Old Jan 23, 2006 | 04:22 PM
mattrem's Avatar
Default FAST manifold progress
Well after a few weeks of figuring a way around the water pump clearance issue I thought I had it figured out I took the TB off today to see if the plan was going to work and its not gonna happen I was going to rotate the TB so it would clear the water pump outlet, but the car manifold moves the TB down so low I can't make it work. So I think I am going pull the tube out of the manifold and weld up the hole. Then cut a new one on a angle and weld in a piece of 1 1/4 tube to miss the DBW motor. Man this thing is a PITA! I see why nobody wants to mess with this. I will try to post pics.
Old Jan 23, 2006 | 04:26 PM
Fogle07's Avatar
could you change to a fbody water pump?
Old Jan 23, 2006 | 04:30 PM
mattrem's Avatar
I want to try to keep from messing with all the pulleys, I have to move the the idler, thats a given. You need to space the fbody pump off the block and make it work, its a different offset.
Old Jan 23, 2006 | 04:41 PM
tdrumm's Avatar
Damn, I just got to open the pics that you sent me before . I thought it looked like it would work, that would have been too easy. The adapter to get the truck fuel rails to fit look good though.
I'm confused by your post though. I assume you are going to modify the pump neck and not the manifold, right?
If you can't post the pics, email them to me and I will.
Old Jan 23, 2006 | 04:43 PM
hellbents10's Avatar
LS1Tech Sponsor
Its not that hard of a swap with the f-body pump.
Old Jan 23, 2006 | 04:46 PM
tdrumm's Avatar
Matt, what about pressing the truck pulley onto a car waterpump?
Old Jan 23, 2006 | 04:52 PM
mattrem's Avatar
I have 2 extra truck water pumps sitting here, so that was the easy way out. Just move the outlet on the pump.
TJ, give me the low down on the fbody pump. I heard its a PITA
Old Jan 23, 2006 | 05:31 PM
blacksheep's Avatar
The easy way around the water pump is to get a 98 F body pump (bolt on pulley) and put spacers behind the pulley. Then put the truck tensioner on the car pump.
Old Jan 23, 2006 | 05:35 PM
mattrem's Avatar
Thanks, I was hoping you would chime in. Is that what you did?
Old Jan 23, 2006 | 08:14 PM
blacksheep's Avatar
It was but now I run all f body accesories.
