FAST LSX 92mm Intake
Old Jun 11, 2008 | 09:50 PM
RSTinOKC's Avatar
Default FAST LSX 92mm Intake
Trying to figure out if this will bolt up to my 4.8, been reading alot of acronyms...LQ, LS, etc...don't wanna buy if it aint gonna fit.
Anyone have any reviews on it coupled with the 92 throttle body and fuel rails?
edit: almost forgot, does a standard cold air fit on a 92mm throttle body? furthermore, if I go with forced induction on down the line, i.e. procharger will I need a new manifold after the FAST?
Old Jun 11, 2008 | 10:00 PM
NoChrome's Avatar
depending on how stock your truck is, that 92/92 isnt going to do much for you. your prolly better off with the truck intake. If you fill in your signature block we might be able to point you in a direction that will offer more hp per $.
Old Jun 11, 2008 | 10:22 PM
RSTinOKC's Avatar
Thanks for the reply NoChrome, but I think I'm headed in a direction with this...the 92 has provisions for direct port *roar*. I'm thinking dual stage - 1 to get it through 3rd gear and one to get it through top of 4th...def dont wanna blow anything up, thoughts and suggestions welcome...also lets not forget my original query - will the 92 bolt up?
Old Jun 11, 2008 | 10:35 PM
Stoichiometric's Avatar
Yes, with the exception of relocating accessory brackets.
Old Jun 11, 2008 | 10:50 PM
RSTinOKC's Avatar
Startin a build here Stoichiometric, cryptic advice is not helpful without links
Old Jun 11, 2008 | 10:56 PM
Sorry.
https://www.performancetrucks.net/fo...ght=ls6+intake
jdb11386
Dec 3, 2015 09:34 PM
The_W
Aug 18, 2015 04:57 PM
omc8
Aug 10, 2015 10:39 PM
Atomic
Jul 11, 2015 03:51 PM
Deceptarado
Jul 8, 2015 05:24 PM
