F1 Procharger 2000 EXT/CAB 4x4
Old Sep 28, 2004 | 08:47 PM
Speed Engineering's Avatar
Former Vendor
Default F1 Procharger 2000 EXT/CAB 4x4
Just thought i would give you guys a heads up on our latest build what we are building. Were almost finished with the project.
2000 Chevy Truck 4wd Extended Cab w/ 8" Lift on 36"s
Project includes
-6.0L Iron Block
-Stock Stroke
-4.030 Bore Diamond Pistons
-Lunati I Beam Rods
-Blower Cam
-Patriot Stage II Heads
-Arizona Longtubes
-Studed & O-ringed block
(F1 Procharger w/12 PSI of boost) 3 Core Intercooler
(Fuel System)
-Areomotive 500GPH Fuel Pump & Regulator
-1/2" fuel line 8AN from the bottom of the tank to the motor (3/8" Line to each rail)
-65 lb. Precision Injectors
We have had it to together once before. The motor spun the crank pully as well as lifted the heads with the heads torqued down to 85lbs. So now we gave the bearings a little more clearance keyed the crank pully and o-ringed the block & heads using copper gaskets. Hopefully the heads stay down. It diffinetly had a ton of power though. Watching the Speedo at 40MPH we stood on it and it broke the 36" tall tires loose pitching it sideways.
Although it is mainely a sand dune toy I would like to get some times and dyno numbers on it before it goes.
Pics and Videos Soon
Sean
Old Sep 28, 2004 | 08:55 PM
Black Blown 02's Avatar
WOW! Can't wait to see the numbers.
Old Sep 28, 2004 | 09:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would suggest pinning the crank pulley Call me.
Old Sep 29, 2004 | 12:30 AM
2toneblown's Avatar
Sounds like my set up but mine is a 408 stroker, 75lb injectors, procharger F1R, and a air to water.
Old Sep 29, 2004 | 11:24 AM
Former Vendor
This original setup was with a radix. But the compressor couldnt keep up with the motor. It seemed like it took years before boost came in. And once it did, it wasnt very impressive.
Old Sep 29, 2004 | 12:14 PM
Texas Terminator's Avatar
11 Second Club
what pulley setup are you using?
Old Sep 29, 2004 | 01:30 PM
Former Vendor
It is the same pulley setup that comes with the factory kit. We just had to update the idler and crank pully.
Old Oct 5, 2004 | 04:54 PM
2toneblown's Avatar
what belt system are you using. 6 rib? 8 rib? 10 rib? Cog?
Old Oct 6, 2004 | 04:39 AM
where can you get the 8 rib pulley set up from? Is it for all the pulleys? I am having trouble slipping the belt on my 6 rib pulley set up with my powerdyne. I already found that the Goodyear Gatorback belt works the best, but I am still slipping it to, with just 6psi and i'm getting ready to put a 9psi pulley on it now.
Old Oct 6, 2004 | 08:06 AM
Scream's Avatar
MOOBIES Moderator
Have any pics of the install? Curious to see how you mounted up the F1.
