Exhaust selection
Old Jun 6, 2006 | 05:18 PM
kitronic's Avatar
Default Exhaust selection
I have an oddball setup on my 02 GMC and am having difficulty finding a bolt on cat-back exhaust system.
The reason it's odd (low production numbers) is I ordered a 2500 light duty, cc/sb, 4x4 with the 6.0. Most are 2500HD (bigger frame etc.) or came with the 8.1.
I'm also running a Procharger at 10psi so I need something to allow more cfm.
I like the big Magnaflow muffler with dual 3" in and single 4" out instead of my dual 3" out to a 3" tip but na for my truck unless I build my own.
I don't want noisy and I want side exit for towing.
From my research about bolt ons; Flowmaster no, Magnaflow no, some others no.
What worked for you?
Do I need to make my own?
Thanks, Kit
Old Jun 6, 2006 | 05:40 PM
TarheelZ's Avatar
Maybe I'm missing something but...don't worry about a bolt-on unless you're planning to do it yourself. Any decent muffler shop can replace your existing muffler with the longer Magnaflow with exit pipe and tip of your choice.
Old Jun 7, 2006 | 03:32 AM
kitronic's Avatar
I can do it all myself which includes the 4" tailpipe fabbed out mandrel bent stainless but that all takes time which=$ so I was looking for a bolt on or a similar way to free up the system first. For example; if someone discovered the bolt-on catback system from Magnaflow that fits the long bed can be altered slightly (hanger placement, length etc.) to fit my shortbed.
Just throwing it out there before I start ordering pieces to build my own.
Thanks again
Kit
flatblack83
Jan 3, 2026 07:10 PM
blown02408
Feb 24, 2016 04:50 AM
EmmerichLSx
Sep 14, 2015 09:47 AM
ferb1e
Sep 1, 2015 08:08 AM
stock48
11
Aug 18, 2015 05:55 AM
