Exhaust Questions
What size is the stock exhaust system?? Am planning on true duels...magnaflow x pipe and magnaflow mufflers. Anyone have the part number for the muffler I need? Wanting it to be half way quiet but still have the rumble.
124-10791 Magnaflow Tru-X Crossover, 2.5" inlet/outlet; 2.5" x 4" center core, 12" length $79.99
124-12226 Magnaflow Universal Muffler, Aluminized Steel, 5"x8" Oval, 14" long, 2.5" offset inlet / 2.5" center outlet $59.99 ..... X2
at www.thunderracing.com
Will this X pipe work? It is still Magnaflow 2.5", just a 3" core and 15" length but is $30 cheaper.
http://www.exhaustproslinc.com/magmanbebxpi.html
Thanks for the help.
Curious.. What's everyones fascination with true duals???
How much more performance do true duels give you over a single/duel muffler??
I still run a single exhaust using the stock piping and Magnaflow muffler. The turbo I have wouldn't work any other way.
I only asked because I see a ton of people that wanna go to true duals for their first mod. IMO it is kind of a waste unless you are going for a particular sound. Most modern vehicles don't gain much if anything by going to duals unless you go huge in power where it may be required. I just see a lot of F-body guys in my club spring for duals and they don't gain squat really and in some cases the car actually sounds worse because of mismatched parts.
I'm not saying what you are doing is wrong at all. I was just curious what the mtoive behind it is and why lot's of people wanna go duals but then don't really do any other mods to the truck besides maybe a Hypertech and air filter. Is it because of the sound or look?
Sorry if I sounded like an ***. I was simply curious
