EXHAUST HELP PLEASE
Old Mar 15, 2002 | 07:47 PM
JUSTINB's Avatar
Default EXHAUST HELP PLEASE
i need help i went the true dual route with two single chamber flows and a x-pipe and have them existing at 45 degrees on both sides in the back, and let me tell you the sound SUCKS can barley hear anything if i cut off the rear pipes and dump it right after the mufflers will get the sound im looking for or do i need to rip the hole thing off and go back to a single 3"pipe instead of two 2.5"pipes please help me find that killer sound i was told about
Old Mar 15, 2002 | 08:47 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: EXHAUST HELP PLEASE
I had a hard time understanding what you just wrote. Do you want it louder or quieter?
Louder = remove the mufflers and run thru the catalytics by themselves
Quieter = change from Flowmaster to a quieter muffler.
Dual 2.5" setup is better sounding than a single 3" setup. Trust me on that one.
Tony
Old Mar 15, 2002 | 08:56 PM
CHAGO's Avatar
i would think the 3" would be too much and lower your compression. 2.5" piping would be good enough. if you want is deeper, than dont get it dumped. i have changed my exhaust like 3 times and i am back with the dumps only because i dont like looking at the piping come all the way back to the roll pan. my dumps sound good to me, and i get looks when i drive by people and hit the pedal. i have hi-flow cats along with jba headers. not sure if that makes it louder or not, but it almost sounds like i have a mild cam in it because it thumps pretty good.
Old Mar 15, 2002 | 08:57 PM
BigTex's Avatar
I read that as you want it louder. Try this: Cut the pipes off after the mufflers. Leave about 1 foot of pipe, but dont do anything for turndowns. See if it sounds better to you. If so, put some turn downs on it and clean it up. If not, then remove the flows.
Old Mar 15, 2002 | 09:09 PM
JUSTINB's Avatar
yes i want it louder, all i have is a rasp out the back but no deep rumble to at all and thats what i want
<small>[ March 15, 2002, 09:10 PM: Message edited by: JUSTINB ]</small>
Old Mar 15, 2002 | 09:42 PM
JUSTINB's Avatar
will replacing the cats with dyno max bullet mufflers help make it louder or deeper
flatblack83
Jan 3, 2026 07:10 PM
kha4079
Oct 29, 2018 04:38 PM
blown02408
Feb 24, 2016 04:50 AM
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
