Exhaust Cut Out Installation
I am looking to purchase an electric cutout for my exhaust but i have a couple of questions.
The stock cat back is 2.75 and you can only order cutouts in 2.5 and 3
Is it ok to just get the 3 inch and weld it without adapters? or do i need reducers on each end?
Has anyone else installed a cutout on the stock cat-back pipe?
MASS seller approved
I would buy a exhaust pipe stretcher and just stretch ur pipe to the 3" opening and then either clamp or weld . That way if there's a problem it's a lot easier to fix . So get the 3" and adapt the exhaust pipe. Here's a link to a cheap one from harbor frieght that will do the trick and its a little more than adapter fittings and extra clamps .
Large Tail Pipe Expander
Hope that helps
Hope that helps
Would you not want to put the cutouts before the cats to get maximum gain? In this case they would need to go in the Y pipe between the manifolds and the cats, which I believe is 2.5" so problem solved. Except now you need two instead of one.
zblee
Aug 3, 2015 03:45 AM
BIGD4504
Jul 28, 2015 11:46 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
