Exhaust 2.5" or 3"
Ok I am going to be getting some new components to redo my exhaust setup this weekend however I am trying to decide whether to stay with dual 2.5" or step up to 3". My LT's are only 2.5" collectors so is there an advantage to runing 3"? I currently have True duals and at WO it is way to raspy/Crackly. I have a ORY with Two dynamax bullets into a Magnaflow mufflers. Idle is quiet, Part throttle is quiet, moderate throttle sounds agressive and WO is annoying. I am going yank the exhaust and put a X pipe right after the mid pipes then go into two Flowmaster 50 series mufflers. The plan is to run about 10lb boost daily with a blower friendly cam so I am thinking I should do 3". What are your opinions?
IMHO, 2.5" is good for duals, easier to fit and lighter to hanger etc,
that's 5" of effective exhaust flow.
you could put a magnaflow dual in/dual out with a built in x-core on it
I had a DI DO magnaflow and didnt like it, sounds just like it does now. Also with the internal X it puts the X too far back. I am going to put my X right after the mid pipes about 4ft infront of the mufflers. I think I might be better off going with 3" hhmmm I need to decide.
I run a true dal setup with X behind the cats. 3" collectors and reduced to 2 1/2" right behind the X thru dual Borla XR-1 12" ovals. There are pics of the setup on my CD page, click my sig if interested.
