everyone with 2001 6.0 or knowledge
Old Dec 28, 2006 | 01:41 AM
Default everyone with 2001 6.0 or knowledge
Will an 01 LQ4 bolt up to my 4l60e? I have gotten mixed ideas whether it was 2001 or 2002 where the LQ4's mated with the 60e's. Please tell.
EDIT*** And if it does NOT fit, is there anything I can do within reason to get it to?
Old Dec 28, 2006 | 01:43 AM
dirt track racer 81's Avatar
mine was supposed to be an 02 lq4 and it bolted up to mine
Old Dec 28, 2006 | 01:52 AM
yea, i know the 2002's are definitely supposed to but somewhere i read that the 01's only did with the 80's....this motor is such a good deal i HOPE it fits.
Old Dec 28, 2006 | 06:10 AM
slowec's Avatar
My 01 lq4 IS bolted to my 00gmc 4l60e with the 00 4.8 flywheel.
Old Dec 28, 2006 | 06:20 AM
parish8's Avatar
single digit dreamer
just the 99-00 dont fit but a good indicator is the heads. if they are iron then it is an older motor and if they are aluminum then it is a newer motor and should fit. that is unless someone swaped the heads on ya. if you can look at the motor you can just look at the crank flange and see if it is flush or if it sticks out a ways, like 3/8" or so.
Old Dec 28, 2006 | 09:05 AM
stone150's Avatar
like parish said, no 99-00's go for 01+
Old Dec 28, 2006 | 09:06 AM
Tootall's Avatar
If you have a 99-00 motor that's going into an 02 how do you make it fit. If there's a flange that's sticking out, can you grind it off, or is there a different fly wheel?
Old Dec 28, 2006 | 09:41 AM
that's the best news I have heard in a long time....It's a short block so I am going off this guys word about the year but i'll look at the flange. thanks everyone
Old Dec 28, 2006 | 10:06 AM
Tootall's Avatar
I didn't want to hijack the thread so I started another one
https://www.performancetrucks.net/fo...d.php?t=382281
SloSVO
Nov 22, 2020 07:34 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
