Enter to Win Contest!
Old Jan 12, 2010 | 12:40 AM
  #41
MikeGyver's Avatar
Intresting results... I wonder were the hardness test was done on the cam... I am starting to wonder if the stiffer springs we all have to run with these larger cams are causeing the cams to wear prematurely on start up....
i doubt it, especially in my case. with 222 and 224 duration and only .333 and .334 lobe lift, it is a gentle cam. my valve open pressure was 420 lbs. these are street cam numbers, biased toward quietness and longevity. nascar engines run 500-600 open pressure, and they open the valves like the front door. i am just opening a window in comparison. and to top that all off, they are using lifters that rub, not roll, on the cam. so i'm sure that this cam was well inside the boundary of safe spring pressure.
you make a good point, but i think you're thinking in the drag race cam kind of numbers.
Old Jan 12, 2010 | 12:43 AM
  #42
MikeGyver's Avatar
Originally Posted by sixltrbtr
Nevermind. I guess I should read all the posts before I post up.
that's ok, good try. see the nurse on your way out, she'll have a little something for you.
Old Jan 12, 2010 | 06:16 PM
  #43
MikeGyver's Avatar
Originally Posted by stock48
Does the lifter still roll or is it froze up? What cam and lifters do you plan to go with next?
I checked today, it rolls as good as a new one.
thompson
31
Oct 20, 2015 03:42 PM
LPCWS6
Sep 1, 2015 10:03 PM
smokeshow
Aug 23, 2015 08:23 PM
