enginehood/clearance????
Old Nov 10, 2009 | 11:28 PM
blklime02's Avatar
Default enginehood/clearance????
hey so im planning some modifications to an HD hood for my 02 silverado....dose any one know how much space is there between the engine top cover and the underside of the hood???
Old Nov 10, 2009 | 11:30 PM
3406a's Avatar
Not exactly sure why you would need to know that? But I bolted one up no problem.. Just have to blend in the fenders.
Old Nov 11, 2009 | 11:42 AM
blklime02's Avatar
well im tryn to fab up a custom hood with a heat extractor...some wat like the 03 cobras.....
Old Nov 11, 2009 | 04:33 PM
budhayes3's Avatar
PT's Slowest Truck
This truck is a different year, but this thread may help you out some: https://www.performancetrucks.net/fo...ght=hood+scoop
Old Nov 12, 2009 | 03:34 PM
blklime02's Avatar
thanks...but he went up...im cuting downwards...in going in..lol
Old Nov 12, 2009 | 03:36 PM
blklime02's Avatar
i think ima have to use some kind of foam that wen pressd down on will retain that form...place it under the hood and close it down see wat comes out....now to look for that illusive foam................
Old Nov 15, 2009 | 08:11 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
there is some stuff we used to use at the audio shop i worked at that was forming foam that once it hardens the stuff is hard as a rock...just cut & mold by sanding...worked pretty well on wood & fiberglass boxes
Old Nov 17, 2009 | 03:19 AM
blklime02's Avatar
hum....name of such foam?? pls.....
i think im just gona go in from the bottom and see if i can get a mesurement like that...
