engine vibration
Old Oct 18, 2006 | 12:21 PM
sinistern2o's Avatar
Default engine vibration
got a 06 sierra 5.3 has a engine vibration at idle - 1,000 rpm .
only have 5,900 mile on the truck and the dealer say's nothings wrong.
any one else having a issue with engine vibrations ?
Old Oct 18, 2006 | 01:04 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Your Idle is at 1000 rpm's????? Should be like 600 from the factory. Yes, a shimmer at idle seems to be 'normal', mine did it too, untill i got it tuned.
Oh, i see you mean idle to 1000rpms. Mine would go away as soon as the rpms came up ober 800 or so.
Old Oct 18, 2006 | 01:11 PM
mine's more than a shimmer , shakes pretty good then smooths out at around 1,100
Old Oct 18, 2006 | 01:49 PM
trever1t's Avatar
Check your plugs/wires?
Old Oct 18, 2006 | 02:12 PM
well I know sometimes new parts are bad but I would think
if it was plugs or plug wires it would set a code for a misfire .
I'm not getting a CHECK ENGINE light or any codes
1bad2k
Aug 18, 2015 09:50 PM
DrX
Aug 11, 2015 07:25 AM
vipergtrdj
Aug 6, 2015 10:19 PM
V-seriesTech
Jul 28, 2015 12:31 PM
bgray
Jul 23, 2015 10:56 AM
