Engine swap: 5.7L or 6.0L?
Old Jul 20, 2003 | 04:02 PM
Default Engine swap: 5.7L or 6.0L?
Well just like the subject says, I'm trying to decide which motor I should buy for an engine swap. Either way, I plan on adding lighly ported heads and a big cam. I've done a lot of reading about the pros and cons of each, but I though I'd post here to get your opinions. If it were your truck, which would you do and why?
Thanks
Old Jul 20, 2003 | 04:19 PM
Smoky02's Avatar
Default Re: Engine swap: 5.7L or 6.0L?
I'm gonna get the 6.0 LQ9, less stuff to convert in the truck and just as much hp, with only a few mods
Old Jul 20, 2003 | 04:34 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I would go with the alum block.If your starting out fresh why not skip the extra 90 lbs.
Old Jul 20, 2003 | 07:07 PM
ChevyTrukRacer99's Avatar
"There's no replacement for displacement" I think that pretty much sums it up.
Old Jul 20, 2003 | 08:38 PM
Thats what I've been thinking too. I know the 6.0 is about 80lbs heavier, but I think a 6.0 bored .030 over would have more than enough displacement to make up for the extra weight. A set of 5.7 heads on the 6.0 should bump the compression up nicely too.
Old Jul 21, 2003 | 10:00 AM
Anyone else have suggestions or opinions?
Old Jul 21, 2003 | 10:28 AM
Vents's Avatar
you could buy my motor ;D
Old Jul 21, 2003 | 11:40 AM
agreif's Avatar
How much do the 6.0's typically go for?
Old Jul 21, 2003 | 01:11 PM
Flem's Avatar
go with the 6.0L and ported 5.3L HEADS higher compression ratio, and they flow better than the 5.7L's even when ported.
Old Jul 21, 2003 | 01:31 PM
Another question...Is there a difference between the 5.3 and 6.0 intake manifolds or are they the same?
