Engine Swap
Old Jul 23, 2007 | 01:30 PM
Toaders's Avatar
Default Engine Swap
Guys I started my engine swap and cannot get the collector bolts off. What can I do I did not want to cut them because I was planning on using the stock manifolds. Headers are just not in the cards right now. Any Ideas? I have not gone far enough to round the bolts off they are still perfect. I have tried map gas and soaking but no luck and unfortunaley I do not have access to air tools.
Old Jul 23, 2007 | 06:11 PM
silveradokidd_4518's Avatar
lots of extensions on your ratchet and a bar
Old Jul 23, 2007 | 06:55 PM
adam1803's Avatar
you could cut them off, then before you reinstall them have studs welded in, or just use nuts and bolts.
Old Jul 23, 2007 | 08:31 PM
pbraxton's Avatar
use a 6 point socket and a 1/2" breaker bar. been there!
Old Jul 24, 2007 | 05:28 PM
Toaders's Avatar
Thanks Guys
Old Jul 24, 2007 | 05:52 PM
gmtechnician's Avatar
let them soak in WD-40 then give them hell.
Old Jul 24, 2007 | 07:22 PM
beedat1's Avatar
Spray penetrant lubricant on them and let it soak in for at least 30 minutes. Then get a big breaker bar and let leverage be your friend.
Old Jul 24, 2007 | 08:51 PM
FstFwrd's Avatar
lots and lots of pb blaster with a 6 point socket, an extension, and a big *** breaker bar. Also, if you can, heat the nuts up
Old Jul 24, 2007 | 11:41 PM
Tootall's Avatar
get a 6 point impact socket. you'll break the ratchet or the studs off before you break the socket.
You're better off getting the engine hot, and spraying the center of the nuts to cool off. Get long break over bar or a pipe, or a fat wrench, and some gloves.
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
