engine swap
Old Nov 3, 2003 | 10:51 PM
Talking engine swap
I got my hands on a 02 ZO6 vette engine with 9,000 mi. I have a 02 GMC sierra rc/sb that I want to swap out the 5.3 for the ZO6 vette engine. I have the complete engine, harness, pulleys, computer, etc. Is this a plug it swap or do I have to cut and splice wires? I thought about purchasing a LS1 edit for the engine after I install it in my truck, will that work? Will I have to beef up the tranny? I really need to know what to do, I have a good idea but im not sure.
Your help would be apreciated-
Robert
Old Nov 3, 2003 | 11:00 PM
2003blue5.7's Avatar
I just put a ls1 motor in my 03 it went rught in and I have had no problems. I have 600 miles on it and I am very happy I did it. pm me if you want to talk on the phone.
Old Nov 4, 2003 | 07:04 AM
L82gofast's Avatar
All your accessories, pulleys, intake etc. from the truck will bolt up to the LS6. You can use your truck pcm and just have it tuned or use edit. I think the injectors will feed it but to be safe you may want to use the 8.1 injectors. That way you don't need to splice anything.
Let us know how it goes, that will be a kick *** truck. I've been thinking of doing something like that myself...
Old Nov 4, 2003 | 07:21 AM
BigTex's Avatar
You may want to beef up the trans. Depending on how hard you are on it, it will let go sometime.
That motor should be a nice addition to your truck. as was already stated, you'll set aside all accessories, intake, wire harness, etc... form the LS6 and use the truck items. The truck should run just fine on the stock tune with the LS6 installed. It won't know it has a different motor. You will make more power if you do get it tuned after the swap, but it will drive fine otherwise. Since the stock shift points are pretty low, you won't be taking advantage of all the new power, but that also means the stock injectors should be OK (at least until you move shifts up to 6200).
Install a torque converter at the same time. Kill two birds with one stone.
Old Nov 4, 2003 | 07:51 PM
thanks for all teh advise guys. I wanted to mention that I have the injectors and intake also, cant I just install the engine as is with all its accessories and injectors and intake. Or do I have to swap everything from the truck engine to the vette engine. What do you think I should do to the tranny? I was thinkingb to go with a trans go shift kit.
Old Nov 4, 2003 | 08:46 PM
Quik's Avatar
5 year bitches!
im not sure isnt there some clearence problems with the ls6 acc. i did
hear of that the oil pan is different and you might need to use the
one out of a truck.
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
