Engine stalls after warmup
Guys this one has me stumped,My motor idles and runs perfectly from a cold start,then stalls after warming to normal operating temp.When it stalls it's like someone turned off the ignition and my wideband AFR shows extremely rich 10 to 11to 1,I can keep the motor running with the throttle as long as the revs stay over about 1500rpm and it will run at about 1100rpm loaded against the convertor.If I slow down below 1500rpm on the highway the motor stumbles and surges like someone switched off the ignition and will pickup when the throttle is applied.The only PCM code I'm getting is insufficent TPS movement.I replaced the TPS and IAC.Has anyone had this problem or does anyone know where to start tracking down the problem.
What was the last thing that was touched on your vehical before this started?Do you have a fuel pressuer gauge?If you can first narrow the symptoms to either fuel or spark related, you will be ahead of the game.
i am very very interested in this!!! I am seeing the exact same thing. First i thought it was because i was running to rich so I leaned it out a bit. As i got leaner in the lower rpms < 1000 I could hold an idle at about 1k for a little bit. But i went and adjusted something else in my tune and the truck is starting to do it again. What is weird is that the truck runs fine just like how you are probabaly experiencing but just wants to fall on its face @ 1000 rpms unless i throttle it.
I know that I did pull the wire running to the ETC so i'll check that as well again to make sure its all good. Also one of the tables i modified changed my piston protection from ~178* f to 255*F. I'm changing that back in about 1 hour and seeing how that affects it as well.
Originally Posted by Allgonoshow
coolant temp sensor out of wack with do that
