engine light help guys...
while back i had a light saying lean bank one and 2.... changed injectors and went away.... now a new one just came on... o2 sensor heater circuit malfunction, bank 1.... and lean bank one and two... whats up guys... bad o2's???
Could be the tune but most likely it is O2 sensors. If you replace them NGK has a new style for LS1 cars, might fit truck applictaions also. I cooked about 1/2 a dozen stockers. Put the NGK's in and no problems since.
not sold on the o2 sensor tho..... bank 1 and 2..... what are the chances both o2's went bad at the same time??? im going to double check intake manifold.... but im leaning more twords a fuel deivery problem....
ok so i just changed out the o2 that threw the code..... seems to have helped....its back to idling good... still not 100% sure that it fixed the lean codes tho... im going to unhook that bat in a minute and clear the codes then take her for a test drive..... if that didnt help the lean im going to check fule pressure.... regulator is only sucking air no gas so thats good...... pressure should be between 55 and 65 psi right??>?
Check and see if there's any K&N oil/debris on the MAF...that can cause a lean code...also check for any vacuum leaks or unmetered air entering the system. If the lean code's still there, go towards checking fuel pressure and the fuel system...
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
bsgiffor
Jul 19, 2015 11:14 AM
