engine light
Old Aug 19, 2010 | 03:24 PM
david0982's Avatar
Default engine light
Lately ive been having problems with having engine misfire when I shift It into 3rd gear and leave it in 3rd gear for a while the engine light will start flashing and then when i go to overdive again it stops again i was just wondering if anybody knew what The deal was with that because it never comes on unless i shift into 3rd. All replys are apreciated thanks.
Old Aug 19, 2010 | 03:35 PM
Atomic's Avatar
I have a gauge for that
When the light is flashing that means the computer is detecting a lot of engine misfires. Check the spark plugs to see if any are cracked, and check the wires to see if any are damaged. Also, go have the codes read at autozone or similiar, just to make sure.
Old Aug 19, 2010 | 03:58 PM
00chevsilv's Avatar
Can you feel a missfire when you are in 3rd or does the light just flash? I've got the same thing except I don't have a physical missfire. I've posted about it on here and got some sugestions but kind of put the issue on the back burner since it wasn't affecting drivability.
Old Aug 19, 2010 | 09:40 PM
budhayes3's Avatar
PT's Slowest Truck
If you don't have an actual misfire, you may have a false misfire from either the characteristics of the cam or the lighter torque converter that's bolted to the flexplate...not sure if either of those would create a problem in third gear only, but it's something to consider
Old Aug 20, 2010 | 09:42 AM
david0982's Avatar
Yea im not actually feeling any misfire the engine light is just flashing Its probably the cam or something because ive put new spark plugs in and new wires and i have checked them out to see if they were cracked but i couldnt find any problems so i was just wondering if any of you guys had that problem so thanks.
Old Aug 20, 2010 | 10:36 AM
00chevsilv's Avatar
Yeah I've got the same problem then. It will only happen in a 500 rpm window between 2500 and 3000 with a light load on (I can pull my trailer in that range and it will stay quiet). I'm logging missfires on #1 and #6 but I have moved around plugs, wires, coils, and injectors and it always stays on those cylinders. It was suggested that I change the crank and cam sensors but I haven't given that a try yet. BTW I'm cammed as well. There is one other person on fsc who is also having this problem but I think he kind of gave up on it too.
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
