Engine knocking. Any ideas?
Old Nov 21, 2010 | 09:41 AM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by CashDudeHomie
Yes it increases proportionally with RPMs. If it is a lifter, would my cam be damaged? I can pull the cam and check if the easier inspections don't show anything.
Depends on where the lifter failed...if it's internal in the lifter, the cam may be fine. If there's a problem with the roller like I mentioned earlier, the cam could have sustained damage. Only way that I know to tell would be to pull the cam and inspect.
Old Nov 21, 2010 | 10:00 AM
  #22
fun4me's Avatar
I've heard that noise before & it was the roller on a lifter. It will also take out the cam. The only way to be sure is to remove the valve covers & see if you can isolate which lifter it is. You will have to surpport the coils out of the way of the moving valve train. I would try to narrow the side to one side.
Old Nov 21, 2010 | 02:29 PM
  #23
MikeGyver's Avatar
My motor sounded like your first video, and I had one ruined lifter and one ruined cam lobe, two cam lobes on the way out, and I forgot if it was one or two ruined main bearings. The bearings were damaged by the ground-up cam metal. It didn't get to sound as bad as yours in the second video, I think you should not start your motor anymore.
ARC
57
Feb 21, 2022 10:54 AM
ullose272
Aug 5, 2016 02:05 PM
lsxperformance
Aug 2, 2015 10:08 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Nimoryan
Jul 5, 2015 03:50 PM
