engine girdle, do I need one?
Old Apr 3, 2012 | 08:23 AM
THE-HOE's Avatar
Default engine girdle, do I need one?
well I've been reading around, but still really confused. I will be running a aluminum ls2 block 408 on boost, and I'm thinking of running like 18lb. also will be running thick deck heads and head studs, so I'm not too worried of lifting a head but Im worried that the aluminum block will be flexing a lot at those power levels. My main caps are stock and not doweled. Are these engine girdles actually proven to help block strength and prevent the main caps from walking? I want this thing to be as reliable as I can, but already having the bottom end together with studs, it would suck to tear it apart and stuff if these girdles Arnt worth it. Thanks in advance for info/ opinions.
Old Apr 3, 2012 | 10:58 PM
THE-HOE's Avatar
ttt for night crew maybe?
Old Apr 4, 2012 | 12:50 PM
gagliano7's Avatar
Try over at LS1TECH someone there will be able to answer your question.
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
