Engine Conversion, which 5.3 to buy?
Old Feb 3, 2007 | 10:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
yes the L33 is the alum. block
Old Feb 4, 2007 | 02:02 PM
cvman's Avatar
Is the '02 and up PCM a better unit?
Old Feb 4, 2007 | 02:12 PM
99Silver6.0's Avatar
Hell yes it is!
Cams:
99 5.3 cam: 191/190 .457/.466 115.5
00+ 5.3 cam: 191/190 .457/.466 114
1999 5.3 only made 265hp versus the 285hp from 2000 up. 290hp in 2004.
Old Feb 4, 2007 | 02:14 PM
cvman's Avatar
Pardon my ignorance, but what makes it better?
Old Feb 4, 2007 | 02:20 PM
99 PCM had serious false knock issues. I wouldnt use one to anchor my boat. 2000's and some 2001's seemed to have that issue to. Albeit not as bad as the 99 but was still existent. 02+ was the key to killing the false KR problem I fought for months in my old 99. The tables written into the PCM are alot better. Updating the PCM cant clean that crap up. I tried it.
Just save yourself the trouble and look for an 02+ PCM.
Old Feb 4, 2007 | 02:22 PM
cvman's Avatar
Great info! Is the PCM specific to either cable or DBW throttle body?
Old Feb 4, 2007 | 02:23 PM
Yes it will be to my knowledge. There is an actual controller for the DBW TB on the firewall. Are you looking to use DBW??
Old Feb 4, 2007 | 02:45 PM
cvman's Avatar
I quess it depends on what year engine I end up with. Low mileage is my main concern buying an engine. Hopefully I can find and '02.
Old Feb 4, 2007 | 04:40 PM
nightrunner's Avatar
Mr. Obvious
even if you get a 03-06 5.3 just swap the TB to a cable and be set
someone corrrect me if im wrong
Old Feb 4, 2007 | 05:01 PM
cvman's Avatar
That would be great if it would work with the PCM
