Engine Bolt Sizes
Old Mar 24, 2017 | 09:28 PM
Hivelocit's Avatar
Default Engine Bolt Sizes
Hello,
Been awhile since I disassembled my lq4. Was wondering if anyone has a size chart for all of the bolts and their placement? If not, all I really need to know is what size the outer bolts are on the main caps; I believe they are 25mm in length from under the flange towards the tip? A look on google didn't turn up much. Thank you!
Old Mar 24, 2017 | 10:03 PM
Wolftrk99's Avatar
http://www.pleasurecraft.com/manuals/L510016.pdf This may help..flund it a while back and has been an easy reference i bookmarked a link to on my phone...
Old Mar 25, 2017 | 01:36 AM
Blown06's Avatar
8 Second Truck Club
Downloaded. Thanks, nice little thing to have within quick reach
Old Mar 25, 2017 | 02:04 AM
Wolftrk99's Avatar
Really surprised i havent posted that link before.... as much as i have used it as a quick reference
Old Mar 25, 2017 | 11:42 AM
Hivelocit's Avatar
Thank you. I love these little cheat sheets!
Old Mar 25, 2017 | 06:05 PM
Hivelocit's Avatar
Hmmm... still cannot find the length, but I am pretty sure they are M8 25mm. Gonna roll with that unless someone else says different.
Old Mar 25, 2017 | 07:22 PM
Wolftrk99's Avatar
Why are you looking for the size? I actually have a couple i had left over when i built my L92, i can measure one but if you are trying to find replacements, you need to get them from gm because they have a sealant under the flange on the head of the bolt!
Old Mar 26, 2017 | 02:13 PM
Wolftrk99's Avatar
Meaured 24.08 from back of head to end of the bolt
Old Mar 28, 2017 | 03:24 PM
Hivelocit's Avatar
Thank you for doing that! I had two sets that looked exactly the same but one was longer. I will use some silicon under the heads when I reinstall; just didn't want to find out I used the wrong size.
Old Mar 28, 2017 | 04:18 PM
Wolftrk99's Avatar
If you have the old ones, they will have that orange ring around them, you can probabky just put a damn of ptfe sealant or some rtv on the flange and be good, so long as you get them torqued properly!!
