Engine
Old Jan 22, 2013 | 05:32 PM
Joe4.8silvy's Avatar
Default Engine
I'm throwing some ideas around , and was wondering if a lq4 or an lq9. Would fit in my nnbs and bolt up to my stock trans and what all would need to be changed , I believe I heard the reluctor wheel would need to be changed but is that the only thin and what about the wiring harness, could my nnbs intake and fuel rails work? That's ahead of time, joe
Old Jan 23, 2013 | 01:34 PM
So i did some reading and finally found that it wont, so is there and short block that i cam swap into my nnbs i have the 4.8 and wanna get a 5.3 but i assume it its has to be of the same year as mine am i correct? And if i found a nnbs 5.3 would my cam and heads swap over? would it bolt up to my trans? and if all that will work will i be able to drive it until i get it tuned? sorry for all the questions im just trying to figue all of this out
Old Jan 23, 2013 | 02:11 PM
TXSZ66AVLANCHE's Avatar
A LS3 will bolt in just finen
Old Jan 23, 2013 | 05:23 PM
Ls3 is a 6.0 correct? I on a little budget at the moment I was looking for a short block to throw my heads cam and intake on
Old Jan 23, 2013 | 05:58 PM
thompson's Avatar
Banned
The ls3 is a 6.2 aluminum block. It is a great motor but is not for the budget minded. The 6.0 will work as long as you get the correct gen and reluctor as GM did make a Gen III and IV as well as a 24 and 58x reluctor. We have 6.0 motors that will be a direct bolt in replacement for your truck starting at $1999. Please give us a call at your convinence and we can get you a great motor.
Thank you,
Kyle
Thompson Motorsports
972-853-0518
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
