eng swap ??'s and its a good one
Old Jul 21, 2005 | 02:19 PM
TURBHOE's Avatar
Default eng swap ??'s and its a good one
ok i've got a lady here who wants to install a small block in her 97 wrangler right now it has a 5spd with 4cly 4wd she says it has no power so we were talking about it and i was thinking maybe a 4.8l or a 5.3 how hard would it be i know they have all the kits to install the small bock like just an old 350 but she would like it to be a little more up to date like no carb so this is whay i said lsx eng any body done this or know how hard it would be. if i could find a 4.8 or 5.3 with a 2000 ecu i could tune it with hpt and turn of like secondary o2's and stuff like that.
Old Jul 21, 2005 | 02:23 PM
white1's Avatar
I think a wrangler with a would be sweet. I would think a kit for the sb would work, but you may need to fab some stuff too. Keep us informed with pics and stuff. I was thinking about getting a CJ and swapping in a 4.8.
Old Jul 21, 2005 | 02:40 PM
TURBHOE's Avatar
well advanced adapters has the motor mounts and other stuff there site gets kinda hard to under stand so i e-mail them for more info so now i just need to find a 4.8 or 5.3 with harness and ecu perferably a 00' ecu i'll get all the pics i can on this one.
Old Jul 21, 2005 | 05:57 PM
Seeing Red Again's Avatar
Speartech can hook you up with the harness. Check out the swap section on LS1 Tech. I believe they are a sponser that frequents that forum.
That would be a blast, and I've contemplated the same thing. It's just a lot of coin to drop on an old jeep!
Old Jul 21, 2005 | 07:46 PM
bluecamaroz28's Avatar
Banned
Go for 5.7 LS1 for the lighter weight. The Wrangler will love it.
The AX5 transmission that comes in the 4 banger will not handle the power of a V8. It often breaks down under the 4 cylinder engine. Swap a 5 speed AX15 or NV3550 transmission from a 6 cylinder wrangler or a 5 speed from a GM truck for better. Adapters are available for mating Jeep transmission to Chevy V8 engines or to mate GM transmissions to Jeep NP231 transfer case.
On the 4 banger, the transfer case has 21 splines input shaft while the AX15 has 23 splins output shaft. So, you may as well need a transfer case along with a transmission from a 6cylinder Jeep where both have 23 splines input/output shafts.
Bumpers
Aug 4, 2024 09:44 PM
OHsixLS3
Dec 27, 2016 09:30 AM
chevyl33
Aug 24, 2015 08:21 AM
GreyChevy
Jul 7, 2015 08:57 PM
ALynch
Jul 6, 2015 09:49 AM
