Emission failed
Old Sep 1, 2016 | 04:59 AM
Go5.3tt06's Avatar
Default Emission failed
Failed emission yesterday say drive cycle evaporated system and oxygen sensor not completely. What we can do? I haven't drive about one week. It been pass emission for 10 years. After turbo and tuned installed start fail emission. No cel
Old Sep 1, 2016 | 05:01 AM
Go5.3tt06's Avatar
Look this. I'm from GA THAT require to pass emission
Old Sep 1, 2016 | 05:30 AM
madmann26's Avatar
These are the readiness indicators. In GA, you can only have 1 readiness test that is not ready and still pass. If you have 2, then you failed (as you stated).
You have to complete a drive cycle. Link is below:
General Motors Driving Cycle
After you complete the drive cycle, take it back to the same testing station and ask him to do a "readiness check". It shouldn't cost a thing and it will tell you which readiness tests are green (ready) or red (not ready). If you have only 1 that is "not ready", then you will pass and ask him to retest it (free for a retest).
Old Sep 1, 2016 | 07:33 AM
Go5.3tt06's Avatar
Yeah need drive more that right?
Old Sep 1, 2016 | 07:45 AM
madmann26's Avatar
Correct.
Old Sep 1, 2016 | 12:57 PM
terravast4's Avatar
do you have a 160 thermostat?
Old Sep 5, 2016 | 09:28 PM
Go5.3tt06's Avatar
I never replaxe tstat. It been factory gm sinc I bought truck brand new past in 2006. Wait on the guy tuner will
Come this Saturday to see what's going on
Old Sep 7, 2016 | 01:10 PM
Tigger Welder's Avatar
I had that on my stock '03 Suburban. I replaced all the stuff in the evap system that normally caused issues. Finally had to build a smoke tester out of a 5 gallon bucket a shop vac and a cigar. Turned out that there was a nipple broken off the charcoal canister right next to the transmission output shaft. Probably got broken with the trans was rebuilt last year. Put the new canister on and a new filter solenoid, it was bad too. Drove it about 45 minutes checking with the scan tool. Once it showed good I went straight to the inspection place. Good to go now. It also helped me find a very slight intake leak. Gasket was failing at the head surface on #1, and #2. Look on YouTube for how to do it, super easy.
Old Sep 7, 2016 | 04:48 PM
Vortec350ss's Avatar
My guess is not a lack of driving but that not all codes were properly turned off after the new tune. Check back with your tuner to make sure they are all off.
I think when you haven't driven enough none of the readiness tests will read complete. Once you turn off ALL the codes for your O2 sensors you will not have a SES light and you will pass the O2 readiness test and be on your merry way.
Old Sep 7, 2016 | 07:34 PM
Go5.3tt06's Avatar
Yes your right I didn't drive that much need drive more. I been use GMC Sierra for daily driver. My tuner will come this sat to check mine
