electronic tb to cable driven?
has anyone converted their electronically driven throttle body to a cable driven? i wouldnt imagine it being too hard just running the linkage. if you did do it did you have to get the linkage from an earlier model at a junkyard or something? let me know
not that simple. you'll need to change the wiring at the throttle body for the difference with the IAC and the TPS, there is a bracket piece missing on the intake that holds the cable casing ends, you'll lose cruise control and I'm sure there's more that I haven't thought of, but it wouldn't be bolt on swap.
You would have to completely change the TB's because one is cable driven vs selinoid driven. Then, you would have to change the ECM, and the wiring to a throttle position sensor. I think it would be a lot of work. I would think a tune on the engine would be much easier and gain similar results.
