Electrical switch question
Old Apr 20, 2005 | 08:09 PM
XLR8NSS's Avatar
Adkoonerstrator
Is this what it looks like?
Here is some info on a SPDT(single pole, double throw) switch which is what it sounds like you're describing.
http://www.kpsec.freeuk.com/componen...h.htm#standard
Old Apr 20, 2005 | 08:29 PM
moregrip's Avatar
what a rush!
this is the exact switch I am using:
http://www.hella.com/produktion/Hell...LED_Rocker.jsp
Old Apr 20, 2005 | 08:39 PM
XLR8NSS's Avatar
Adkoonerstrator
The 12 volt goes to the middle prong and then you run a wire from the lighted terminal side to whatever you're powering. The ground on whatever you're powering is then hooked up to a vehicle ground. The "off" terminal on that switch is not used.
You could use the "off" terminal as a "on" terminal also like to switch power between two different devices. It's all said in that link I posted above.
Read the "ON-ON Single Pole, Double Throw = SPDT" section and look at the diagram on the side.
Old Apr 20, 2005 | 08:43 PM
XLR8NSS's Avatar
Adkoonerstrator
The switch could also be used to switch the ground instead of the power wire.
GXPJAY
Feb 13, 2022 08:15 AM
713truck
Aug 18, 2015 09:32 PM
USMCvet0311
Aug 1, 2015 07:45 AM
