Electric water pump for 4.8 05 silverado?
Old Sep 12, 2010 | 08:11 PM
eallanboggs's Avatar
They're not cheap. SDPC has the best price. You will have to cut the top hose to make it fit because the top neck exits the pump at a different angle. You will also have to cut the top plastic fan shroud a little bit because the top hose will be routed differently. You also have to use a GenI small block thermostat. I use a 160 stat. The pump bolts right up and you use the same serpentine belt. You use a 12Vdc ISO relay and trigger off of the fuel pump relay. When the key switch is turned "ON" the fuel pump is energized by the PCM. What I did was turned the fuse panel over and cut the insulation off of the coil wire for the fuel pump. I soldered the coil wire for the water pump relay to this wire. This energizes the water pump when ever the fuel pump is turned "ON". You can figure this stuff out as you install the pump.
5.3Okasai
Mar 9, 2022 01:07 PM
ullose272
Aug 5, 2016 02:05 PM
chopperloco
Jul 10, 2016 10:45 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
