Electric Fans Won't Work... what could be the problem?
Old Sep 13, 2007 | 09:44 PM
benvortec's Avatar
Default Electric Fans Won't Work... what could be the problem?
I installed LS1 e-fans with DLH2006's harness. I followed the instructions for the installation but they won't turn on. What green wire is it that you splice into? I spliced into the solid dark green wire that was supposed to be the AC wire but the fans don't turn on when my motor gets hot or when i turn the AC on. I also checked to see if the green wire was hot when the AC was turned on but it wasn't. I also checked the other 2 green wires(one with a white stripe and one light green) the light green was hot at all times when the key was turned over and the other was never hot... so I don't know what it could be. My positive and ground are good so help me out
Old Sep 13, 2007 | 09:45 PM
RandomHero's Avatar
lol, just to make sure you do have a tune right?
Also the fans won't come on unless:
1.) the temperature goes above the seat number. Mine is set to turn on a 205* and turn off at 200*.
2.) You turn the a/c on
My setup 99% of the time in warm weather turns only one fan. In cold weather 99% of the time neither will be turning.
Old Sep 13, 2007 | 09:50 PM
Derek @ EDO's Avatar
FormerVendor
hey man,
to check the harness ground out the PCM pin, the fans should come on low!
take the AC wire and touch the + battery while the pcm pin is grounded and the fans should come on high.
Check all connections!! Ground and Power!!
sounds like a bad ground.
Old Sep 13, 2007 | 09:52 PM
nonnieselman's Avatar
First things are first...
Check and make sure you are gettin power to your Relays.
Check your grounds.
I believe that the A/C wire is natural Green.
Turn the A/C on the highest level with the Recirculation on.. That should keep the AC clutch locked. ( I cheated, i used EFI Live to manually Engage the AC Clutch )
Check your relays by jumping them and check for voltage on the Output of it.
You should be able to ground the wire that you ran to the PCM and the fans come on low..
The wire that you have goin to the A/C, you should be able to connect it to +12v and the fans should come on.
I Dont know how the harness you have works. But this should be correct.
Old Sep 13, 2007 | 09:53 PM
Originally Posted by DLH2006
hey man,
Ok, we said the same thing...... you put it in a few words compared to my Paragraph....
Old Sep 13, 2007 | 10:00 PM
benvortec's Avatar
hey man,
What if Nelson didn't tune in my fans? How could i check that?
Old Sep 13, 2007 | 10:03 PM
FormerVendor
just touch the pcm pin to a ground!
you can splice into that wire on the harness instead of running it to a ground.
you can also touch the ac wire to the battery, if the pcm pin isnt grounded one fan will come on high!
Old Sep 13, 2007 | 10:04 PM
Find someone around ya to Scan the PCM and check the Fan Settings???
You could run a mini switch in the mean time if it came down to it..
Old Sep 13, 2007 | 10:12 PM
benvortec's Avatar
thanks alot guys! I'll everything yall mentioned tomarrow and then fill ya in on what the problem was!
Old Sep 13, 2007 | 10:14 PM
FormerVendor
sounds good bro, im about to PM you my cell# where you can get in touch with me directly if you have any specific questions!
flatblack83
Jan 3, 2026 07:10 PM
MA$TER_E
Sep 9, 2015 03:14 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
