electric fans
Old Jul 13, 2005 | 10:22 AM
Default electric fans
what all do i have to do for e-fans and how much will it cost???
Old Jul 13, 2005 | 10:34 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Whick kind you want? 05 efans you have to get a 34" radiator and the fans that will run you about 500 bucks plus a 80 buck nelson harness to run it. Flex a lites are arounf 300 or so. LS1 fans are around a 100 bucks from the junkyard and you have to get a nelson harness or on efrom someone else. The 05 setup will give you the best cooling and is what I will eventually end up with in my truck.
Old Jul 13, 2005 | 10:51 AM
i guess i'll probably go with the 05' set up!!
Old Jul 13, 2005 | 11:03 AM
1slow01Z71's Avatar
I fyou need help installing it I might happen to be in town to help you out. PM me when you get the stuff I live in DP when Im in texas.
Old Jul 13, 2005 | 11:12 AM
ok thanks will do!!
Old Jul 13, 2005 | 11:22 AM
mrb04's Avatar
i have the 05 efans and i beleive a 34" radiator that is what is measures across how do you tell because it dosn't look like it will work the truck is a 2004 5.3 rcsb with the tow package and trans cooler
Old Jul 13, 2005 | 12:36 PM
white1's Avatar
I got my LS1 fans for $100 and am using a $60 temp controller from Pep Boys to turn them on/off
Old Jul 13, 2005 | 01:31 PM
Coban's Avatar
Ls1 fans $90 shipped from member
nelson harness $85 shipped from member
Old Jul 13, 2005 | 01:56 PM
1slow01Z71's Avatar
I fyou have 05 efans then you have a 34" rad to my knowledge the 05s wont work on the other smaller rad.
Old Jul 13, 2005 | 03:15 PM
CAMMIN03''s Avatar
Banned
yeah I was going to say... if you do the install yourself.... less than 200 bucks
thats a nelson wiring harness... and ls1 or lt1 fans...
