electric fans
Old Jun 18, 2004 | 12:06 AM
trokita5's Avatar
Default electric fans
Does any one know about how much hp would I get If I put two electrical fans & a 160 thermostat. Also do I have to get a new fan belt. '03 Sierra r/c 4.8,Nelson Tune,K&N,3.73 wt loc diff
Old Jun 18, 2004 | 01:12 AM
I don't know why we have a search button. Nobody uses the damn thing.
Old Jun 18, 2004 | 08:22 AM
retsell's Avatar
Another reason why we need a smiley beating a dead horse.
But to answer your ? you would get 150hp.
Old Jun 18, 2004 | 09:13 AM
dowright82's Avatar
That would depend if you got a RE-TUNE or not. If you already have the Nelson Tune, and you get the thermostat + Fans, then the only way to take advantage of the cooler engine temperature would be to get a retune which would advance your timing a little bit . . ..
I believe Allen will do your retune for only the price of shipping . . . .
Also, about 12-20 hp probably . . . much better throttle response!!
Old Jun 18, 2004 | 09:28 AM
BigBlockChev572's Avatar
Lightbulb
I would have to say you would get 8 HP or less from an electric fan. Remember, electrical fans still take away from HP. You don't get something for nothing in this world. If you used a Flex-a-lite direct fit fan, which draws 28 amps, you would lose .5HP from the 8 HP the electric fan gave you. As the generator on a vehicle has to supply a larger amp load, it becomes increasingly hard to rotate (more resistance is encountered). Resistance or friction as we know reduces HP. In other words, Flex-a-lite's fan's for around $400 probably isn't worth it unless your trying to squeeze every ounce of HP out of truck if cost isn't an issue.
Philip S.
Old Jun 18, 2004 | 09:33 AM
just get ls1 fans and rig them up. their 1/4 the cost of flex's.
Old Jun 18, 2004 | 12:59 PM
dowright82's Avatar
Default Vsc Unit
Where can I get the Flex-a-lite VSC unit to rig up my LS1 Fans??
Old Jun 18, 2004 | 02:14 PM
FLATOP08's Avatar
Give Allen a call at www.nelsonperformance.com he has wire harness that he made for the LS1 fans. I have a set and you just plug and play.
Old Jun 18, 2004 | 02:16 PM
Hit Man X's Avatar
7-9rwhp over a nonlocked clutch fan sounds about right...considerably more over a locked one. Throttle response is much improved and slight powergained when the stock fan isn't locked. Also eliminates that "WHRRRRRRRRRR" also from the stocker when locked.
Yes working the alt more ot run the fans is a downside, but if they are run at lower speeds (as with a VSC or DCC setup) the difference would be like having your head lights on...
02Denali has a 40A VSC for sale in the For Sale section.
I'm running LS1 fans with a 40A VSC, works great.
Old Jun 18, 2004 | 03:35 PM
nekkid_hill_billy's Avatar
plus they save gas...this is my next mod....with it being a 1.99 a gallon and driving over 50 miles a day thats always nice.........and you guys wonder why i love my 4.8 so much and would never go for the bigger motor. 22hwy 18 city mpg out of a 4x4 .
