Electric Fan Install
Old Jan 21, 2004 | 04:09 PM
Question Electric Fan Install
I am installing LS1 fans next Monday... trying to get all my parts and info together now. Do I have to have the VSC control module from Flex-a-lite in order to run the fans? Is there anyway I can just hook it up to a switch in the cab so I can turn them on or off? I really dont want to spend an extra 100 bucks on the module, I hope there is something out there cheaper and easier to do!
Thanks guys,
-Kurt
Old Jan 21, 2004 | 04:11 PM
one03sierra's Avatar
Formerly one92rs
Talking
yep you can go with a hayden temp relay and stat set up. usually you can get them from the auto parts for around 40.00 bucks.
Old Jan 21, 2004 | 04:23 PM
02 Denali... do you still have your Hayden temp relay? And is it possible to just use a simple switch to give it power or is some sort of module needed?
Thanks!
Old Jan 21, 2004 | 08:48 PM
sleepersilverado's Avatar
are you saying you just want a switch to turn the fans on and off. i have mine wired to were they come on when the truck is on, then flip the switch and they are off, then flip it again and they are on with the truck off.
Old Jan 24, 2004 | 08:31 AM
agreif's Avatar
This won't help you much with the wiring, but hopefully will with all the other crap.
http://james.jaguar.net/agreif/fans/fanstech.htm
Andrew
mr03silverado
Aug 13, 2015 11:40 AM
razorshot
Aug 10, 2015 08:10 PM
Ketis
Jul 23, 2015 12:37 PM
