elec.fan conversion 04 Denali?
Old Jul 23, 2007 | 04:48 PM
Originally Posted by SS_bnoon_SS
Hey, no problem! Nice to know there's one more smartass on the forums.
Seriously, there's nothing to it, and nothing is different from GMC to Chevy. The only thing that makes a real difference is running large vs small radiator. The LS1 fans are a good choice for either (they cool my LQ9 SS just fine in 100 degree heat with AC blasting). I got my LS1 fans for $60 shipped with a broken tab on them (didn't need it anyway since it was a lower mounting tab that you don't need putting them into a truck), so it can even be cheap to upgrade. I think I spent another 20 bucks putting together the wiring harness including connectors and pins.
Do you know if the 04 denali has the 34" radiator? I will be in touch with you , i would like to do the LS1 fans! Thanks for the info!
Old Jul 23, 2007 | 05:13 PM
chuckie311's Avatar
all you have to do is measure the radiator and you will know if its a 34"
Old Jul 23, 2007 | 05:34 PM
03sierraslt's Avatar
If it is in fact a denali then it has a 6.0 which has a 34" radiator. I have efans on mine. It took all of about 15min to install them including the wireing.
Old May 23, 2023 | 03:15 PM
Mctooslow's Avatar
Registered User
Default Wiring
where did you get the wiring? What all comes with it?
Old May 23, 2023 | 06:05 PM
RB04Av's Avatar
5 Year Member
There's an EXCELLENT technical writeup in the ... wati for it ... Technical Write-Ups forum on this site. Like this one. https://www.performancetrucks.net/fo...-chevy-484892/
All you need is the entire fan system out of a newer truck. Fan assy, bolts that hold it in, harness, and the fuse box piece that has the relays in it. It's all a stand-alone; not part of the main harness, therefore very easy to gank intact.
You'll find that EVERYTHING ABOUT IT bolts RIGHT UP to your truck. The bolt holes for the fan assy are even already there with the nuts welded in.
Basically all ya gotta do is: remove all your existing clutch fan stuff (shroud, fan, clutch), bolt up the fan assy, plop the relay assy in (your truck already has the place for it), hook it up, and enable the fans in the tune. You do need to add 1 pin to the ECM and connect it to the relay assy. Way too eeeeezzzy.
You'll also find that the fans from a still newer truck, maybe 11 or 12 or so, with more powerful motors and more blades on the fans, will bolt in just as well. If you can't find a good used 06ish fan assy at a price you're willing to pay you can just get that from rockauto or some such.
Huntingman2706217
Sep 9, 2011 09:56 AM
ryan_wagnon
Dec 29, 2009 07:06 AM
xturboguyx2001
May 16, 2008 02:33 PM
OrlandoFL4.8
Dec 8, 2007 08:22 PM
jow02327
Feb 15, 2005 09:42 PM
