EGR pump removal
Old Aug 5, 2008 | 10:02 PM
BARBER's Avatar
Formerly pimpeterbilt 4/26/10
Default EGR pump removal
Once I get my retuned PCM from Charlie Wheatley I'm going to pull the EGR pump off my 5.3. He turned it off through the computer, and I need some other tips on doing this or is there anything else that needs to be done before pulling it off. I still got my block off plate for the pass. side header too. Anything else I need to do or get? Thanks.
Old Aug 5, 2008 | 11:23 PM
GMCtrk's Avatar
I'm just going to leave mine on.
But I think you just take it off and block off the holes and you should be good to go.
Old Aug 5, 2008 | 11:29 PM
nonnieselman's Avatar
For the Intake manifold you can buy the factory block off plate or make something to cover it..
Old Aug 5, 2008 | 11:55 PM
just go to advanced and buy the rubber freeze plugs to fit the whole on the intake i did it and it works perfect theres 2 sizes they were like 3 dollars so i got both.
Old Aug 6, 2008 | 12:16 AM
00ChevyScott's Avatar
Wearin' da big hat
I used a rubber expandible freeze plug which works great.
GXPJAY
Feb 13, 2022 08:15 AM
nrmskate
Aug 11, 2015 02:44 PM
