EGR or not to EGR...that is the question.
Old Oct 18, 2003 | 11:44 AM
Hit Man X's Avatar
Default EGR or not to EGR...that is the question.
EGR is the exhaust gas recirculation. Supposedly makes lower NOx levels and such at lower RPMs so helps emissions. Lets say you had to get your vehicle tested with a sniffer as well as the OBDII scan, could it pass w/o WGR?
So...is there any reason to keep in on the vehicle? GM did get rid of it in '02 and up vehicles...anyone know why?
Old Oct 18, 2003 | 12:04 PM
Yelo's Avatar
Default Re: EGR or not to EGR...that is the question.
GM changed cam profiles that year to include more valve overlap so you are getting the same effect as having EGR.....it's just happening in the combustion chamber instaed of in the intake manifold
Old Oct 18, 2003 | 12:07 PM
Hit Man X's Avatar
Cam profile changing...what was changed on it? LSA or reverse split?
Old Oct 18, 2003 | 09:52 PM
Banned
LSA was changed on the cams, basically if you have LS1 edit you can turn the EGR codes off so you wont have an SES code and you'll pass all emissions tests.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Velocity1
Oct 12, 2015 10:39 PM
dantheman1540
Sep 18, 2015 03:03 AM
Pimpinpete
Sep 8, 2015 07:39 PM
