Effect of Stall converters?
Old Jul 29, 2003 | 09:47 AM
TG02Z71's Avatar
Default Effect of Stall converters?
What is the seat of the pants feel like? Does the stall converter rating, (ie: 2800 stall)effectivly not let the drive train engage until it reaches this stall rpm? Or does it only have this effect at WOT? A high stall would seem to cause a loss of every day drive-ability. Is this so?
Does anyone know the factory stall rpm for a 2002 sc Z71,5.3l.3:73 ? Please advise. Thanks.
Old Jul 29, 2003 | 10:07 AM
11 Second Club
Default Re: Effect of Stall converters?
Factory stall is 1600-1700 rpm. The drive train is still engaged during low RPM operation. With a loser converter you can brake stall to a higher RPM, you get more flash and shift exstension is much higher. Between shifts the shift exstension keeps your motor running at higher rpms, which keeps your motor in a better power range. Yes you can take off before you get to 3000 rpm's.
Old Jul 29, 2003 | 11:12 AM
TG02Z71's Avatar
I see, then with more power would less stall be needed to acheive the same acceleration?
Old Jul 29, 2003 | 01:06 PM
Deckhand's Avatar
Yep,
But the more stall with more power = WEEEEEhooo!! lol
Old Jul 29, 2003 | 01:12 PM
Flyer's Avatar
I wouldn't go to radical with your stall though. I would get a Yank 2600 or 3000 at most. I have the 2600 in my truck and love it. I rhink rhw truck should come with a bigger convertor. It amkes it a lot sportier to drive.
Old Jul 29, 2003 | 04:12 PM
11 Second Club
3000 stall and all the power you can muster is what you want.
Old Jul 29, 2003 | 11:02 PM
JSmith's Avatar
Also, don't let anybody talk you into going less than a 2600 stall. I'm still kicking myself for not putting the Yank 3000 stall in.
Old Jul 29, 2003 | 11:09 PM
954RR's Avatar
what about for just everyday drivability? and then the occasional drag race from a stop light. which is better a 2600 or a 3000? and what effect will it have under "normal driving" on the tranny?
Old Jul 30, 2003 | 06:25 AM
TG02Z71's Avatar
Good question 954RR, lets hear the opinions.
Old Jul 30, 2003 | 08:25 AM
Patrick G's Avatar
LS1 Tech Administrator
Listen to the guys running them. A 3000 stall is very liveable on the street. I've been running a 3000 stall in my heavyweight Tahoe for 3 years as a daily driver. I absolutely love it. I'm thinking of going bigger soon so do 3000 stall at a minimum.
