efans. hp worth the $$$
Old Jul 13, 2008 | 04:57 PM
reveille5's Avatar
Default efans. hp worth the $$$
If so. What parts would be needed?
Money to spend to get all the right parts are not an obstacle.
Old Jul 13, 2008 | 05:11 PM
Derek @ EDO's Avatar
FormerVendor
I think they are worth it. Most guys see a tenth increase in the 1/4
The thing I like most about them is the OPEN engine bay, it looks really clean and makes working on the truck alot easier.
You can add E-fans for around 200.00
that includes the fans and harness.
Derek
Old Jul 13, 2008 | 05:19 PM
fastnblu's Avatar
What's your ride?
I think so, even tho they're on my to do list. I like that there's less drag on motor, & they clean up the front area, & give ya a lil room up front.
Harness could be purchased from Trick or Nelson, but there are prolly others too. I'm unsure on relays to control on/ off & programming.
For fans. A whole slew to pick from. Flexalite, LS1, I think some even use LT1 fans. I think Spal & Permacool make as well.
Or just order the whole deal from Trick.
Old Jul 13, 2008 | 05:23 PM
fastnblu's Avatar
Derek
I see Derek posted on the sano look while I typed. If u can score all for $200, that's not bad. Here I figured $400-$500 for when I do it.
Old Jul 13, 2008 | 05:39 PM
chevrolet all the way's Avatar
i have a setup in my closet right now that i have $185 in but you also have to have your pcm tuned to make them work and also im pretty sure you have to have a 34" radiator
Old Jul 13, 2008 | 05:43 PM
FormerVendor
Nope, LS1 fans with the 28" radiator fit like a glove
Old Jul 13, 2008 | 06:05 PM
charcold-bowtie's Avatar
If ur a turbo guy, makes intercooler routing easy. Cleans up the engin bay a lot.
Old Jul 13, 2008 | 06:30 PM
GMCtrk's Avatar
To me, I prefer the clutch fan. My dyno guy said I might pick up 10hp with the E-fans. But, to me it's not worth the cost and the potential chance of overheating when I tow.
Old Jul 13, 2008 | 06:36 PM
chevyguy7802's Avatar
I say there worth it! Like others said it really does open up room under the hood!
Old Jul 13, 2008 | 06:39 PM
fastnblu's Avatar
I plan a Radix. I should prolly do the fan swap 1st.
GMCtrk, true, 10 hp is a lot for $200 or more...but I don't tow, & if I ever do, it would be something small...say a Jet Ski.
