efans and 160 thermo.
Old Jul 5, 2005 | 10:20 PM
Default efans and 160 thermo.
I just got done installing the LS1 fans and a 160 thermostat and took it out for a little ride and it got up to 210. I had previouly installed this stat before and removed it. do you think it could have gotten damaged in the few months it was sitting in the box. I currently have the fans programmed to turn on a 180 and turn off a 160. I also have a toggle to manually control it. I also went to pep boys and got some water wetter and it works, to a point. I dont know waht else to check. any input would help. thanks.
Old Jul 6, 2005 | 05:47 AM
one03sierra's Avatar
Formerly one92rs
Talking
thos etemps are to low on the fan settings. even though it is a 160 therm it is going to run 180 most of the time. when i had mine i set them at 189 on and 182 off.
Old Jul 6, 2005 | 07:39 PM
I thik the stat is the problem. I used to run the A/C when I first installed the stat and it wouldnt move from 180. I posted teh temps wrong. whats the deal, should I just buy a new stat.
Old Jul 6, 2005 | 08:32 PM
qwank's Avatar
check for air in the system, this is usually the main cause of running hot in these trucks. i have efans and a 160 stat and it runs right around 190
Old Jul 7, 2005 | 07:37 AM
I'll check for that later on today, thanks
Old Jul 7, 2005 | 07:55 AM
BIG Newton82's Avatar
check the stat... I've got e-fans and a 160 and the only time it even reaches close to 200 is if I let her sit and idle for a while
Old Jul 7, 2005 | 04:03 PM
A little bit of air can make these motors overheat in a hurry. You have to be sure to bleed it all out as you are filling the radiatior back up...
Old Jul 7, 2005 | 06:57 PM
In the mornings when I dont use the A/C it runs right at 180. at stoplights, traffic and so on. but in the evening when its 100 degrees and I use the A/C it gets up to 200 quick. I dont know, I checked for air and I bled it for a while, still does the same thing.
Old Jul 7, 2005 | 08:44 PM
normally if it had air in the lines, it would overheat no matter the situation. You may wanna go ahead and pick up another t stat....
Old Jul 7, 2005 | 10:39 PM
budhayes3's Avatar
PT's Slowest Truck
So it sounds like it only runs warm when the a/c is on. Are the fans running on high when the a/c is on? If they're just running on low, it may not be enough to cool both the condenser, and compensate for the extra load on the engine from the a/c compressor.
