edit users i need an answer
Old Jan 23, 2004 | 05:41 PM
one03sierra's Avatar
Formerly one92rs
Talking edit users i need an answer
are you locking your converter in third or just overdrive.i have mine set up not to lock until i get into fourth gear and at 57mph. but i have read that some are still locking there converter up in third gear. if so what mph are they locking at.
Old Jan 23, 2004 | 05:49 PM
Flyer's Avatar
I would lock it if you aren't getting into it, or above 80-90 depending on gears and how your truck pulls.
Basically the converter should be locked if it isn't under decent acceleration, so that when your cruising around in 3rd, it will lock when it's just cruising to prevent it from building up to much heat.
Old Jan 23, 2004 | 06:30 PM
ThunderZ28's Avatar
12 Second Club
i wish mine would just lock
someday it will........
Old Jan 23, 2004 | 10:00 PM
Formerly one92rs
Talking
cool so you can program it to lock up under normal acceleration and not lock up under wot???
Old Jan 23, 2004 | 10:05 PM
ThunderZ28's Avatar
12 Second Club
yep!________
Old Jan 24, 2004 | 01:43 AM
Flyer's Avatar
Yes ... under the TCC lock tables.
Old Jan 24, 2004 | 03:00 PM
BigKID's Avatar
I have mine set to where it wont lock up till 42mph in od with light throttle. It progressively gets higher than that with throttle position. You can scale TCC lockup in third and fourth for what mph you want it to lock at depending on tps.
zblee
63
Jun 10, 2023 01:25 PM
Verz
Aug 21, 2015 06:40 PM
Dirtywhite
Aug 5, 2015 04:18 PM
Hmguyton
Jul 7, 2015 03:29 PM
