Edelbrock intakes?
#31
Nitrous pro flow inline dual stage plate
NX Shark plate
you have to think about the vic jr intake design to, and how the spray bars are drilled and be sure on the even distribution of nitrous/fuel to all cylinders,
the NX plates spray down the middle like the other plate but they also spray fuel and nitrous from all 4 sides of the plate...just a thought
#32
the only thing i really like about that plate is the burst panels, look at the nx shark plate it would be a cheaper alternative but doesnt have the burst panels
NX Shark plate
NX Shark plate
#34
#37
Its progressive. It is very touchy, you wouldnt want it to be 1:1 on the street. I have a hard enough time just barely touching the gas pedal and not spinning the tires.
#38
I also had to cut my throttle cable.
I took a small bolt that screwed into the heim end. I put it in my lathe and drilled a hole the size of the cable all the way thru it. Then on the other end of the bolt (threaded side) I drilled it bigger. Then when I stuck the cable thru the bolt I kinked the cable and poured some molten lead inside of it that way it can never come out. This way I can adjust the tension on the cable.
