ECT how hot is TOOOO hot????
Old Jul 1, 2009 | 07:31 PM
Grumpy5.3's Avatar
224 is fine..... most cars with efans, kick on around 227-228....
food for thought, bigger radiator means more water to keep cool... Not saying the 34 in radiator is a bad investment, bc of more surface area.
Old Jul 1, 2009 | 07:37 PM
terravast4's Avatar
I run a 160 stat with the 40k trans cooler and my heat exchanger in front of the radiator and in 100+ weather it wont go over 180 water temp.
Old Jul 1, 2009 | 07:41 PM
00ChevyScott's Avatar
Wearin' da big hat
Our stock thermostats are 187 degrees.
Old Jul 1, 2009 | 07:44 PM
thunder550's Avatar
High on diesel fumes
FWIW, I have a 34" radiator now with OEM truck fans and a stock thermostat. I have a 40k trans cooler and a Maggie heat exchanger in front of the radiator. I towed our boat up a large hill in boost for about 2 mile straight with the A/C on and the ambient temp over 100* and the highest I ever saw my ECT was 214.
Old Jul 1, 2009 | 08:01 PM
phasemaster1's Avatar
Originally Posted by thunder550
You have a stock thermostat? I had a 160 and a 180 and during the summer my truck would try to overheat on me all the time (with 34" radiator, and with both factory e-fans and a factory clutch fan). As soon as I went back to stock it's all fixed. I think the coolant was not spending enough time in the radiator to cool down properly.
Same here got hot to 210-224 when I went to ls1 fans and 160 thermo for some reason, went back to stock clutch fan and stock thermo hangs at 208.
Old Jul 3, 2009 | 09:18 AM
fastrt's Avatar
11 Second Truck Club
I say stock 34" setup and stay cool, my truck stays around 199* all the time. I have a lingenfelter(spell?) 180* and saw no improvement over a stock t stat.
Old Jul 3, 2009 | 10:33 AM
dlt76028's Avatar
i got to get a new thermostat or put the clutch fan back on cuz my truck was idling in a shop and hit the line before 260 and would not come down .
Old Jul 3, 2009 | 12:53 PM
KLUG'S SS's Avatar
FormerVendor
It was around 95 degrees here a couple weeks ago and setting idling in the drive thru I watched my temps when I was logging go up to about 230-240 and I had never had my truck do that ever, had it since it was new.
New stock thermostat, stock 34" radiator, stock fan clutch. I might try another new thermostat and see what happens maybe even might go with at least a 180. It was strange because I have been through 5 summers with this truck and the 90+ degree temps have never caused it to heat up like that.
Old Jul 3, 2009 | 02:31 PM
BlackGMC's Avatar
Resident Retard
Well i got my fan connectors today from DC_Justin for the 05+ efans. I will be ordering a new 34" radiator ($165 shipped) and some new 07+ efans ($212 shipped) in a day or so... Interesting thing while researching this 05-06 efans have 1 fan with 5 blades and the other with 7 blades. The 07+ both have 7 blades... HOpefully i will know next weekend if that solves my problem...
Old Jul 3, 2009 | 05:02 PM
OrlandoFL4.8's Avatar
Here in orlando my truck will get upto 217-223~ with ls1 fans stock thermostat And stock radiator in stop and go and when I'm cruising will stay around 195
