Are e-fans worth it?
Old Dec 18, 2005 | 11:22 AM
magnetized's Avatar
Default Are e-fans worth it?
I'm tossing around the idea of adding the gm fans. I've got an LM7 w/the factory tow package, but I still assume I've got to swap out the radiator correct? How about the Nelson harness for it, it isn't as simple as plug-n-play is it? I've got to splice it into the electrical system right, which could f-up my warranty if I screw it up. I guess it all comes down to this: Is the gain in performance and mpg worth the trouble of buying all the goodies and installing them?
Old Dec 18, 2005 | 11:26 AM
CHarris's Avatar
The nelson harness is very easy to install. The only wiring splicing it takes it inserting one pin into a PCM connector. It took me about a half hour to do after I stopped being stupid and looking in the wrong place... lol It installs very neat and clean and looks close to factory in my opinion.
I did notice a SOTP gain even with the RADIX!
While I did remove mine due to Radix/Cam/E-fan conflict... I still have the harness and intend to go back to E-fans with the new turbo after it is installed.
Old Dec 18, 2005 | 02:06 PM
Jethro_3's Avatar
You will also need to have the PCM programmed to turn the fans on.
Old Dec 18, 2005 | 04:49 PM
samdogmx's Avatar
8 Second Club
there are much cheaper ways to go about adding an E-fan.
I spent under $150 for everything to do mine.
e-fan from ls1 f-body
an adjustable thermostat
a 30 amp circuit breaker
some wiring & connectors
Old Dec 18, 2005 | 07:29 PM
.T.'s Avatar
.T.
PM if you want a set of used '05 E-fans w/Nelson harness.
I documented a 7% increase in HP on a dyno before and after installation on the same day. That was on my 04 LM7 w/Whipple. Instead of preaching HP/TQ numbers, it quantified to a 7% increase at the rear wheels-period.
Easy mod and well worth doing.
Old Dec 18, 2005 | 09:10 PM
bluecajun5.3's Avatar
11 Second Truck Club
i think they are worth it. back when my truck was runnin 14's i could feel a diffence in sotp...
Old Dec 18, 2005 | 09:17 PM
CoonToot's Avatar
I did the same thing for $120 total...has worked perfectly for 18 months now.
Old Dec 18, 2005 | 09:21 PM
Originally Posted by Formulated
ok so from what i read the fans off an LS1 Fbody can be used, what radiator will be needed?
stock radiator will work fine. i have my ls1 fans zip tied....
