e-fan wiring problem
Old Nov 7, 2006 | 03:00 PM
Nick™'s Avatar
stop driving around, get the truck good and hot and grab a beer and watch it go, if the gauge reads that it's overheating (with the a/c off) then there's a problem, otherwise the fans should come on
Old Nov 7, 2006 | 07:59 PM
dirtyratt's Avatar
If they used the factoy settings for the Series Parallel Fans they wont come on till
226 deg its starting to get cold here in michigan and mine havent come on in a month unless I use defrost or a/c im using pin 33 I think it was. and pin 42 one is for a/c and the other was for temp
Old Nov 7, 2006 | 08:44 PM
Wilde Racing's Avatar
How do I change this text
Originally Posted by blake2kz71
He also told me to ground the pin to make sure the harness and the fan motors work. Il figure it out.
see, I told you... lol
Old Nov 7, 2006 | 09:44 PM
Nick™'s Avatar
Nelson sets his for temp on Pin 42
Old Nov 7, 2006 | 09:51 PM
blake2kz71's Avatar
Thanks a whole lot fellas. Iv never seen a thread like this with no bullshit just straight up good advice. It has been a learning experience thats for sure. Problem was the pin wasnt all the way through. I didnt know the wire and all had to be in and it had to be pushed as far as the factory pins. but oh well no harm done and now i can give advice b/c i know i wont be the last one to have this problem. Everything works fine and the fans come on around 190 and go off at w/e temp like there supposed to. Thanks again
Old Nov 7, 2006 | 10:18 PM
Glad to hear you got it fixed and it was cheap to fix it!
Old Nov 7, 2006 | 10:20 PM
blake2kz71's Avatar
yeh it was....cost me alot of time but i dont mind i always gota have something to tinker with or il go crazy
Old Nov 8, 2006 | 01:07 AM
thunder550's Avatar
High on diesel fumes
Good! I had the same problem, so I understand the process. "I know I got it in there far enough!!" I said it too, but I was wrong.....
Glad you got it fixed.
Old Nov 8, 2006 | 05:33 PM
blake2kz71's Avatar
it still took some time to get the wire and all to go through, all it needed was a lil wd40 motivation and it went right in.
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
