E-fan/Thermostat ?
Old Dec 1, 2004 | 10:12 AM
Default E-fan/Thermostat ?
my SS seems to run at about 210F. If i was to replace the t-stat, with a 160f, and got an ajustable E-fan temp control switch, What temp should I set the efan temp stich to turn on at??????? Does any have the GM part # for the Ls1 fans from the vette of camaro?????
Old Dec 1, 2004 | 10:27 AM
creederado's Avatar
the hot new thing now is the 05 electric fans that come standard on the 05 1500's.
You radiator is already the correct size.
It bolts right up.
There's a few ways to wire them.
I purchased a harness through Nelsonperformance. Saves me the headache and time.
You have a few operating choices.
forum link
With a nice truck like that Ilike to use factory parts now that there available.
As far as the fans go.
https://ls1tech.com/forums/showthrea...highlight=fans
Old Dec 1, 2004 | 11:07 AM
pirate3's Avatar
I bought an electric fan from the junkyard out a mid 90's ford taurus with a 3.8 motor and it keeps my truck around 180 all day. The fan cost me $25 and I wired it so it comes on when my truck is running. It also fits nicely under the shroud and pulls very little current when running. FYI
Old Dec 1, 2004 | 01:03 PM
marc_w's Avatar
I'm not exactly cure what temp you should turn the fans on at with a 160 stat - but I want to say the minimum you'll run is around 175 or so. So maybe 180?
I'm running the stock t-stat and I have my fans set to turn on at 212*F. They hardly ever run. I've been considering getting a 160-stat, and wiring up a switch for dual-temps. (easy as pie with the DCC fan controller). I'd run the 212 I use now for daily driving, oil life, emissions, etc. etc.... but then switch to a 180 setting or so when I'm at the strip or towing.
Old Dec 1, 2004 | 02:39 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
On at 185 off at 175. Of course, I set mine to come on a 100* and go off at 10*...
But hey, I live in hell.
Old Dec 1, 2004 | 03:08 PM
mattrem's Avatar
I have the Flexalite 282s with the Nelson harness, I use a 160* Thermosat, mine runs a 185 all day. The fans come on a around 190.
Old Dec 1, 2004 | 04:38 PM
If I Buy 1/2 Ton E Fans And Nelson Harness Do I Have To Re Flash Computer To Except Fans
Old Dec 1, 2004 | 04:43 PM
Old Dec 1, 2004 | 05:12 PM
one03sierra's Avatar
Formerly one92rs
Talking
ye sif you buy a nelson harness you have to have the pcm corrected for it and have it turned on. for the 160 therm it comes on at 189 and off at 182.
Old Dec 1, 2004 | 05:15 PM
What Kind Of Prices Am I Looking At I Can Buy The E Fans From Dealership For About 320 With No Wiring
