E-fan setup??
Old Nov 19, 2004 | 05:18 AM
  #41
one03sierra's Avatar
Formerly one92rs
Talking
man that is a lot said there. i hear you. hope you got them wired up and working. did you use the derale. or another one. i know what it is to be spending the dough. i have a ton invested in mine. every once in a while i will try to do something a little cheaper for the moment to be able to splurge later. i guess some will never understand that part.on the other hand if they read all post and what is sayed then they wouldnt make those other comments. good luck.
Old Nov 19, 2004 | 08:36 AM
  #42
marc_w's Avatar
I think e-allen's gist of his post was that he was concerened because there were some basic questions being asked about modifying and setting up a rather high-priority item in the engine bay. He was harsh, but I think he means well.
I think there are a fair amount of "gotcha's" when wiring your own e-fans with custom parts... You'll probably read a few stories on here about relays melting and trucks overheating. A good handfull of FAL controllers failed too. I highly recommend the DCC controller if you want a very reliable way to get things running without going into the PCM.
I have the ability to setup my computer to run my fans, but I don't have much interest to. The DCC unit only turns the fans on as much as needed - no big "WHIRRRRRRRRRR" when they turn on. (unless you're running the A/C, which sets them to 50 or 60%.).
Old Nov 19, 2004 | 10:56 AM
  #43
bodyguard6799's Avatar
I'm setting up my fans w/ the Derale because thats the cheapest way I can do it until I can afford a tune. I want the fans now because I have them and I would rather have them on my truck than just sitting in the garage collecting dust. When I get my tune I will probably hook them up throught the pcm. I guess some people just cant understand that.
Old Nov 19, 2004 | 11:44 AM
  #44
I still want to know which one you guys think is better, the rad probe or screw in probe. THANKS!!
Old Nov 19, 2004 | 12:06 PM
  #45
If you could find a place to screw in the probe I would use it, but I couldn't. They seem to work just as good either way, so I would probably just get the push in radiator fin probe.
Old Nov 19, 2004 | 12:21 PM
  #46
marc_w's Avatar
I don't know the difference... FAL and DCC use a probe that sticks into the fins of the radiator. That works fine for me...
Old Nov 19, 2004 | 05:17 PM
  #47
Sounds good. THANKS!!
Gadgetized
Oct 22, 2015 09:06 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
old motorhead
Sep 29, 2015 08:22 PM
