E-fan setup??
Old Nov 13, 2004 | 06:26 PM
bodyguard6799's Avatar
Default E-fan setup??
Alright, I just bought some LS1 fans off e-bay. I cant hook em right now, what I want to know is, should I take my whole fan shroud (top & bottom) off or should I leave the bottom half on and why?? THANKS!!
Old Nov 13, 2004 | 06:36 PM
one03sierra's Avatar
Formerly one92rs
Talking
take both off. the fans will have there own shroud that will work good.
Old Nov 13, 2004 | 06:57 PM
Thats what I was thinking but I thought someone said to keep the bottom half on for something. THANKS!! Oh, I wanted to check out this harness from Allen but dont know where to go. THANKS!!
Old Nov 13, 2004 | 08:00 PM
Formerly one92rs
Talking
pm sent.
Old Nov 13, 2004 | 08:35 PM
Mater's Avatar
did u find the harness?& were?
Old Nov 13, 2004 | 08:41 PM
joshluther's Avatar
You can buy the harness here http://www.nelsonperformance.com/ But you still have to have them turned on on your pcm
Old Nov 13, 2004 | 08:42 PM
Mater's Avatar
thanks
Old Nov 13, 2004 | 09:22 PM
Thanks!! I guess nobody would just turn the fans on and set the temps in the pcm?? I would like to get HP tuners later but I want to hook up the fans asap and dont want to spend money doing it not using the pcm and I dont have any mods yet to tune for much less $$$.
Old Nov 13, 2004 | 09:56 PM
Formerly one92rs
Talking
well if you want just the fans you can get a relay system from hayden from the local auto parts usually for around 25.00.
Old Nov 13, 2004 | 10:20 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Are you talking about just wiring them up with the thermostatically controlled switch? I don't have edit or a custom tune, and I was hoping to wire mine like that. Does that work decently?
