e-fan problems??
Old Oct 6, 2006 | 12:22 PM
ap2002's Avatar
Default e-fan problems??
my truck keeps on heating up with the a/c on in stop and go traffic, if I turn off the a/c its ok though?? well, today I got home and did a little r&d, with my a/c off both of my fans are on and on low speed, when I kick on the a/c only one fan kicks in on high and the other one shuts down completely?? this is a nelson harness and I have probably put about 3 sets of relays thinking that was the problem... so what can I do??
I am very tempted on just putting a toggle switch and running them on high all the time
splice some wires to hook up the fan that shuts down to the fan that is on high when the a/c is running,??
what do ya'll suggest??
thanks...
Old Oct 6, 2006 | 12:51 PM
thunder550's Avatar
High on diesel fumes
That's how mine reacted when I had a bad relay in there. You sure all of them are good? Are you putting in 30 or 40 amp relays?
Old Oct 6, 2006 | 05:34 PM
bigredexpress99's Avatar
hey thunder, I know you've been dealing with the relay thing for a while, what part numbers have you been using for the relays? I'm building my own harnesses exactly as GM builds them,only I cant use the relays they spec, so I was curious as to the ones that most are using and finding success with?
Old Oct 6, 2006 | 06:56 PM
thunder550's Avatar
I don't have any part numbers (sold my e-fans and harness). I got them from Napa though, and made sure they were 40 amp relays. I believe they were the only model they carried.
Old Oct 6, 2006 | 07:25 PM
jakebdb56's Avatar
I personally would just leave the fans on high all the time if I could. Cools more efficient.
your problem with the harness, I would contact nelson about it if you think the harness is faulty.
Old Oct 6, 2006 | 09:32 PM
I am so hijacking this thread...anyways, thanks a bunch man. I'll go relay hunting tomorrow....
Old Oct 9, 2006 | 05:52 PM
ls1CANTU's Avatar
9 Second Club
I have a three relay harness kit that i use and never had any probems with it. fans kick on high speed when a/c is on.
Old Oct 9, 2006 | 06:10 PM
i use a toggle swtich but the harness is from matt so i dunno but it works
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
